1.3 Rocam exhaust question
Tbird
Make: FOrd
Model: KA
Type: Ka
Post by Tbird » Mon Jun 12, 2017 7:30 am
Hi Guys,
New to the forum, I have a 2005 Ford Ka 1.3i bone stock with just under 107k on the clock. Been thinking about doing some performance mods (yes I know its only a 1.3 and a waste of time and money but its what I have to work with)
I have read about some nice torque gains from using an SWR branch manifold but I was thinking of putting a free flow on first, is this wise or should I rather save and first get an SWR branch? Would a free flow on its own make any kind of difference even?
Any advice would be appreciated.
Thank you
2005 Ford Ka 1.3
For any crossfit or just fitness enthusiasts:
http://crossfitsouthafrica.createaforum.com/index.php
TS.170
Re: 1.3 Rocam exhaust question
Post by TS.170 » Mon Jun 12, 2017 5:10 pm
The freeflow will just sound better but wont give any real gains. The branch might give slight gains but again not much. Remove the catylitic converter may help especially if its old and blocked. Note you will need a fooler to switch off the engine light if you do a de cat. Do not go bigger on the exhaust pipe diameters as its been proven that you loose tourque. Hope this helps
Molten orange 2014 Fiesta ST
2010 Honda VFR1200 f
Ex 2010 Fiesta Titanium 1.6
Ex Focus ST 225
Ex Focus ST 170
Tbird
Make: FOrd
Model: KA
Type: Ka
Post by Tbird » Tue Jun 13, 2017 7:54 am
TS.170 wrote:The freeflow will just sound better but wont give any real gains. The branch might give slight gains but again not much. Remove the catylitic converter may help especially if its old and blocked. Note you will need a fooler to switch off the engine light if you do a de cat. Do not go bigger on the exhaust pipe diameters as its been proven that you loose tourque. Hope this helps
Awesome thanks bud, im not expecting miracles LOL and ive heard that just doing a free flow back box on these is more beneficial for a 'better sound' than a full free flow.
2005 Ford Ka 1.3
Kory-ST90
Make: Bantam
Model: Rocam
Type: ST-90+
Post by Kory-ST90 » Tue Jun 13, 2017 4:34 pm
Do the branch and cam make a big difference if you in the reef go 47 to 50mm if coast can do 50mm and mandel bend
Ford Bantam ST-90
    SWR Branch
      SWR Cam
      • Unichip-Q
      • Uprated Fuel Pressure Regulator
      Motorcade SRI Induction K&N Filter
      • Gasflowed Head
      • Piper Road Tech Exhaust
      And Many More To Come...........
      TS.170
      Post by TS.170 » Tue Jun 13, 2017 6:48 pm
      My brother did full system and cams plus unichip on hes 1.3 rocam fiesta and got just over 60kw. We then bought 1 of Novel Fords Ford KA GTs which they did an engine swop with the 1.6 motor. That was also modified with cams , Full exhaust and software eventually making over 100kw. That was a little monster and was great fun. I enjoyed that more than the Focus ST 170 I had at the time.
      Ex Focus ST 225
      Ex Focus ST 170
      Tbird
      Make: FOrd
      Model: KA
      Type: Ka
      Post by Tbird » Wed Jun 14, 2017 7:35 am
      TS.170 wrote:My brother did full system and cams plus unichip on hes 1.3 rocam fiesta and got just over 60kw. We then bought 1 of Novel Fords Ford KA GTs which they did an engine swop with the 1.6 motor. That was also modified with cams , Full exhaust and software eventually making over 100kw. That was a little monster and was great fun. I enjoyed that more than the Focus ST 170 I had at the time.
      100kw in a car that handles like a gokart would definitely be fun LOL
      2005 Ford Ka 1.3
      Return to “Ford Performance Mods”
