Turbo target AFR
Turbo target AFR
Postby Bloubul7 » Tue Sep 16, 2014 8:59 pm
Hi guys,
I have done a bit of online reading and can't get a clear answer. What would the perfect target AFRs be when going forced induction?
Model: RS3
Type: Revo 2 S-tronic
Re: Turbo target AFR
Postby nanovapour » Tue Sep 16, 2014 9:25 pm
12.4 would be perfect.
Current : Audi RS3 | REVO 2
400whp & 640Nm @ FR&R
11.9 at RaceSA event Aug 15
EX : CW Roc 2.0TSi
250wkw 507Nm @ KAR
12.5 @ 180km/h (Dragwars 2013)
12.5 @ 185.8km/h (Dragwars Invitational 2013)
241km/h - 1km @ ODI (Sept 2013)
Postby Shanks » Tue Sep 16, 2014 10:04 pm
nanovapour wrote:12.4 would be perfect.
+1
Current:
11 Focus 'ST'
Celtic Stage 3
6R Polo GTI
REVO 2
Type: 350R
Postby Oom Piet » Tue Sep 16, 2014 10:07 pm
I have an Innovate Motorsport AFR gauge in my car and I run 14.5 under cruising, 12.4 fair acceleration and 11.4 under full throttle and full boost.
Celtic Tuning added more fuel when the throttle is planted.
Dreamscience C21 Software
SAIC Intercooler
Karter Performance Boost Pipes
RS Fuel Pump
RS Turbo
RS Internals
Darton Sleeves
AS Motorsport Custom Induction
eBoost Controller & Gauge
Innovate AFR Gauge
OB1 Powered
Type: White ST225
Postby Umlungu » Wed Sep 17, 2014 12:32 am
Its dependent on the characteristics on the applied engine.
This is because AFR is a very delicate ratio which will determine how fast the fuel burns within the combustion chambers(burn rate).
On a N/A motor like yours that is turbocharged, it will be different ball game as the fuel is heated from the n/a high compression.
That itself establishes a faster burn hence why you wont advance a lot on the ignition as the pressure point will be at peak at low degrees.
Power AFR lies anywhere between 11.5-13 AFR, you unfortunately cannot be lectured on what AFR's is best because 1 degree of timing advancement unfortunately changes the AFR.
The way I used to tune was that i would quickly get the AFR to 12 and then start advancing whilst watching the AFR go leaner and listening out for detonation with my Knockphones.
When you hit Detonation instead of pulling timing, change the AFR richer and leaner slightly and see if the detonation per throttle angle gets worse or less.
You will notice, the more fuel you add, the more power you loose, the leaner it is the more likely it will detonate the fuel.
Thats the perfect AFR(whatever it is), between power loss(rich) and detonation(lean)...
Unfortunately you need a dyno for this advice.
BTW - its better to run a ball hair rich for the cooling and safety aspect.
For all your Performance Accessories visit:
Visit http://www.performanceproducts.co.za/
Performance Products SA
