Rocam 1600 throttle body size OD and ID?
Postby Skaap » Wed Nov 19, 2014 8:53 am
anyone know of hand what size it is?
i have this idea to build my own induction for my bantam, but i believe using a smaller diameter pipe, it will increase the airflow speed from the induction, thus giving more power egor.... also the longer the tube, the more torque is gained, the shorter the tubing, the more speed. so i want to find the middle ground.
LOUD pipes Save LIVES!!
Chicks dig me because im FLUFFY!
98% of people hate Jeremy Clarkson. If you are part of the 2% which doesn't, put this in your sig!
Re: Rocam 1600 throttle body size OD and ID?
Postby Eon » Wed Nov 19, 2014 9:23 am
Skaap wrote:anyone know of hand what size it is?
I have a spare one lying around at home. Will measure it tonight for you. Regarding the 'tubing', are you not confusing the induction pipe dimensions with the intake/inlet manifold runner dimensions? I have also been doing some research on intakes and AFAIK, the thickness and length of the tubing only applies to the individual manifold runner pipes that come after the throttlebody, and before the inlet ports of the head. Anything before the throttlebody doesn't matter what thickness or length really. The temperature of the air it's sucking should be more of a concern. I have recently experimented by putting a 1600 intake (thicker and longer runners) on my 1300 engine, and noticed a decline in low-down torque, but it revs better in the high rpm range. I changed it back because I preferred the torque.
Postby leon » Wed Nov 19, 2014 9:48 am
**** skaap, leef jy nog? :shock: Looooong time Bru!
Postby Skaap » Wed Nov 19, 2014 12:54 pm
Eon, yeah sorry man.... yeas after the throttle body, but im sure if you smooth out the airflow before the throttle body you will see some gains, not so much on my NA, but a turbo car even more.
oom Leon, ja natuurlik.... onkruid vergaan nie.
