How to turbocharge your 1.4 duratec Figo/Fiesta
Re: How to turbocharge your 1.4 duratec Figo/Fiesta
Postby PoopandPee » Thu May 14, 2015 2:25 pm
Stu wrote:personally I would of rather done this on a golf with an ABF in
rather concentrate on getting your cabbie back on the road :lol:
Model: figo
Type: pre-facelift
Postby ricardo930927 » Sat May 23, 2015 10:45 pm
--Quick Build Update--
Sorry that ive been quiet guys... quick update and pics on the build.
-Turbo Mods-
When i bought this t25 turbo i was faced with 3 problem. one being it didn't have a vacuum nipple on the compressor housing for boost signal to waste gate, i didn't have the correct size oil return flange and finally had to sort out how im running coolant through the turbo parallel with my heater lines.
with regards to the oil return flange it was a simple fix, just drilled the original holes bigger and slotted the flange so i could use a bolt and washer to lock it down.
With the return flange done, i needed to grind two m14 fittings so that i could simply hose clamp normal radiator hose from a t piece fitting running inline with the car heater (bypasses heater)
Now the fun part. Taping the compressor housing. using a 8mm drill bit and a 1/8npt tap you can make a threaded hole which almost any vacuum nipple you get will fit.
-Some Inter cooler prep-
Using a dremel or any other rotary tool you can cut away at the front grll to make space for the inter cooler and piping.... i could of cut i little less of the grill of near the sides but i went a little crazy whilst cutting. none the less im sure it will still look great when its all in. I had to cut away at a part of the front impact bar to make the intercooler fit snug.
Build is coming along. dont expect project to be 100% done till July.. doing it bit by bit as i can but im sure it will be done before august. will upload more info and pics as build progresses as always
-Some random build pics-
I needed to cut an old induction pipe so that i can connect it inline with a oil catch tank to where the positive crank valve would be to drawer constant vacuum from connecting it to the pre compressor side of turbo. the oil catch tank should do a decent job at preventing oil from hitting the compressor blades and doing possible damage, whilst keeping my car emissions friendly
Model: 1.6i trend
Type: Fiesta
Postby Wallyracer86 » Sun May 24, 2015 4:31 pm
The project is looking good recardo.
Model: figo
Type: pre-facelift
Postby ricardo930927 » Sun May 24, 2015 5:17 pm
Wallyracer86 wrote:The project is looking good recardo.
Thanx man, just keen to finish it ASAP!
Model: figo
Type: pre-facelift
Postby ricardo930927 » Sat Jun 13, 2015 2:42 pm
Had time to do my intercooler piping this Saturday, Was pretty basic..i used silicon hose primarily. you will need 8x 90degree 50mm bends, 1x45degree 50mm a bend, 1meter straight silicon pipe, numerous connectors and hose clamps, realized i need a 30cm straight aluminum pipe, to connect the BOV t piece to the intercooler bends so it passes the radiator hose.
To cut the silicon i found the best and simplest DIY way is just placing a hose clamp on the pipe where you have measured for your desired cut, tighten the clamp and run a Stanley blade along the hose clamp for a smooth finish.
The intercooler itself fits very snug once you have cut away the grill as i have, it does not require you to remove the front bumper to mount the intecooler, just angle it and press it in. i find installing the pipes onto the cooler to be easier than trying to put them on once the cooler is mounted in place
This is how the intercooler bends look wen its not on the car
Space is a bit tight as the turbo will be behind the engine in the most common setup, with the charge pipes coming over the engine/cam pulleys and down next to the alternator, it requires one aircon pipe to be bent out of the way, it will not break as long as you dont over bend it, just enough for silicon pipes to pass.
How it all looks once installed
As always ill keep uploading updates as build progresses.
Make: BMW_Opel
Model: 1er_Corsa
Type: Hatch_Ute
Postby gavsadler » Sun Jun 14, 2015 6:41 pm
Loving the stealth look, keep up the good work
Model: figo
Postby st for life .co.za » Mon Jun 15, 2015 9:57 am
epic looks tops
Current 2015 ford figo 1.4(Mods) pending
ex 2006 Fiesta ST
Mods
Aftermarket touch screen radio
10inch jbl sub + 2 6x9
2800 watt 4 channel amp
aline grace rims
Powerflow xhuast
K&N 57i cold air induction
power brake gt disks and pads
Type: T5 R
Postby kbracer » Mon Jun 15, 2015 11:48 am
gavsadler wrote:Loving the stealth look, keep up the good work
+11111
Volvo C30 T5 R-Design
5Pot FTW
Type: T5 R
Postby kbracer » Mon Jun 15, 2015 11:49 am
+11111
5Pot FTW
Postby Stu » Wed Jun 17, 2015 7:08 am
coming along nicely
Model: figo
Type: pre-facelift
Postby ricardo930927 » Sat Jun 27, 2015 9:22 am
Bad news guys, i have to put the build on hold till closer to the end of the year, as i have fallen into a bit of a financial situation as Ive been roped into going to the UK with my fiance, and plane tickets aint cheap. The build will continue but only after i get back which is int October. Sorry guys just have to wait a little while longer
Type: ST180
Postby LinuX MAN » Sat Jun 27, 2015 10:07 am
Great progress so far 8) , hat off to you bud.
2014 Ford Fiesta ST
Ex: Ford Figo
Ex: Ford Focus 2004 1.6
Model: FIESTA
Postby VFR » Sat Jun 27, 2015 3:01 pm
Well done man... Excellent workmanship... I'm sure you can source more Intel in the UK.... This trip may be a blessing in disguise ... Enjoy !
Model: 335i
Type: Sedan
Postby Icemanz » Sun Aug 16, 2015 11:14 am
Wow this really awesome to see, good luck with it looks like it is going to be a little terror and will make for a perfect sleeper car keep up the good work
Model: figo
Type: pre-facelift
Postby ricardo930927 » Mon Nov 23, 2015 11:17 pm
Howsit gents
Last edited by ricardo930927 on Mon Nov 23, 2015 11:21 pm, edited 1 time in total.
