Polly filled engine Mounts - Pre FL 225
Make: Volvo
Model: C30
Type: T5
Re: Polly filled engine Mounts - Pre FL 225
Postby PoLonY » Sun Aug 02, 2015 7:48 am
Also it just carries the mass of the motor, the torque mount prevents the rotating force.
I don't see the benefits of poly filling those 2 mounts tbh unless they have popped and to fill them is cheaper then replacement. But for performance I don't see benefit
07 Volvo C30 T5 met eish
Postby Pooven1979 » Sun Aug 02, 2015 12:27 pm
Polony, I think the idea is that high power will rip the stock engine mounts.
I also have all poly filled mounts. Vibrations are only slighted more than stock.
Make: Volvo
Model: C30
Type: T5
Postby PoLonY » Sun Aug 02, 2015 1:23 pm
Pooven1979 wrote:Polony, I think the idea is that high power will rip the stock engine mounts.
If the torque mount is stiff enough then they will not move and therefore can't rip.
The torque mount controls the movement, those 2 mounts simple carry the weight of the motor
That's why you got barely any vibration from your poly mounts, cause they don't do anything but hold the motor up.
Make: Mitsubishi
Model: Lancer Evo Ralliart
Type: slow
Year: 1996
Postby general_lee » Sun Aug 02, 2015 9:59 pm
I have filled all the ST'S mounts.. and as Poling so rightly says is true.. the top mount and one under battery carry weight ..
I always ask the person if they want serious race bits or just something better than stock..
I do 30shore all the way up to 90shore
Just a stock Jap car
Postby PoopandPee » Mon Aug 03, 2015 6:41 am
What about Pauly Shore?
Return to Ford Performance Mods
Users browsing this forum: Baidu [Spider] and 2 guests
