Polly filled engine Mounts - Pre FL 225
Postby Pooven1979 » Fri Jul 31, 2015 9:23 am
Hi guys
A buddy of fine needs these urgently.
Anyone have stock?
Thanks!
Re: Polly filled engine Mounts - Pre FL 225
Postby Bloubul7 » Fri Jul 31, 2015 9:31 am
Pooven1979 wrote:Hi guys
Anyone have stock?
Thanks!
DIY, buy some SikaTack and fill the mounts
Postby Pooven1979 » Fri Jul 31, 2015 9:36 am
Anyone have stock?
Thanks!
Thanks bud. Will let him know
Make: volvo
Model: s40
Type: T5RS
Postby hanov0 » Fri Jul 31, 2015 10:32 am
I have inserts in stock for the torque mount
Modding Fords since 1985
http://www.saicperformance.com
Postby Boolee » Fri Jul 31, 2015 10:40 am
it'a amazing the difference this one small change makes.
Postby Pooven1979 » Fri Jul 31, 2015 12:52 pm
Thanks Hano, but my Friend is looking for Engine and Gear box polly filled mounts.
Postby ash » Fri Jul 31, 2015 1:48 pm
Pooven1979 wrote:Thanks Hano, but my Friend is looking for Engine and Gear box polly filled mounts.
Ashley fron Koni stocks the Powerflex inserts.
Call him
011 918 2292
Make: volvo
Model: s40
Type: T5RS
Postby hanov0 » Fri Jul 31, 2015 3:24 pm
On the engine mount you are not going to find a poly fiiled one. Whole unit needs some surgery with another mounting inside
Gearbox one I havent seen any one filling those. Except for the OTC one for the 250
If all mountings are solid that thing is going to rattle your false teeth out....
Postby Pooven1979 » Fri Jul 31, 2015 4:02 pm
Do you have stock of these?
Make: volvo
Model: s40
Type: T5RS
Postby hanov0 » Fri Jul 31, 2015 4:33 pm
yes
Postby transformer » Fri Jul 31, 2015 6:08 pm
All my mounts are poly filled. Gbox, engine and torque mount. No excessive vibrations
Postby German » Fri Jul 31, 2015 9:17 pm
I can get the hardware set.
Transformer, remember it all depends on the density of the urethane used.
Postby transformer » Fri Jul 31, 2015 9:51 pm
German wrote:I can get the hardware set.
yebo! they measured the stock rubbers, went slightly stiffer than stock
Postby German » Fri Jul 31, 2015 9:55 pm
Phone corrected there. I was meant to say hard race and not hardware...
Make: volvo
Model: s40
Type: T5RS
Postby hanov0 » Sat Aug 01, 2015 5:47 pm
Filling the stock engine mount doesnt make sense, the oil just keeps the bottom rubber soft, thats why when it leaks out the rubber just
tears. Thats why the whole inside needs somekind of new rubber mounting bolted in or a complete different setup.
