Ford rocam 1.6 forged pistons
Type: 1.6L
Postby Destro » Wed Oct 07, 2015 2:06 pm
Halo guys
Im in the prosess of putting together a turbo kit for my 1.6 bantam , the only thing im struggling with is decideing if i need forged pistons or can i just ceramic cote the standard ones, im only looking to boost 0.5 to 0.6bar but i want to do a good job any advice plz
Re: Ford rocam 1.6 forged pistons
Postby ash » Wed Oct 07, 2015 2:10 pm
Destro wrote:Halo guys
contact bloubul on the forum.
Type: 1.6L
Postby Destro » Wed Oct 07, 2015 7:43 pm
Can you help me contact him ? Im still new to the forum and im struggling to contact him
Postby MrMazda » Wed Oct 07, 2015 7:53 pm
Send him a pm to ask him to look at your thread. He will get back at you
Postby Bloubul7 » Wed Oct 07, 2015 8:31 pm
Hi,
Im currently running 0.5 to 0.6 bar on stock pistons without a problem. The key is your tuning (timing). My compression was dropped through headwork
Forged pistons are hard to come by for the Rocam, you would have to have a set custom made.
I feel that 0.5 is perfect, I drive on 0.3 bar as an everyday day. On 0.3 bar it made 112wkw and 198nm.
See my project thread for some history
viewtopic.php?t=76508
If you have any questions feel free to ask
Type: 1.6L
Postby Destro » Thu Oct 08, 2015 5:05 pm
I would like toe know , i have a unichip installed on the bakki , can i use it for my turbo tuning if i add the unichip turbo module ? Would the chip be adequate for my aplication ? And what is the standard injector size on the rocam ?
Postby Bloubul7 » Thu Oct 08, 2015 5:34 pm
Destro wrote:I would like toe know , i have a unichip installed on the bakki , can i use it for my turbo tuning if i add the unichip turbo module ? Would the chip be adequate for my aplication ? And what is the standard injector size on the rocam ?
Im not too familiar with UniChip but do know of some other people that have used them on turbocharging.
If I recall correctly the std injectors are 130cc or 170cc, I will have to go and check. But I can confirm that they are too small too use. Try looking for some 2nd hand ST225 injectors, they are direct fit.
Type: 1.6L
Postby Destro » Mon Mar 21, 2016 7:02 pm
So i have a question, the 1.6 rocam motor bore is 82mm but the closest forged piston i can find is a 85 mm so thats a 3mm oversize , my question is can i bore the block of the rocam that much to fit these pistons ? I realy want to turbo the bantam and boost a bit more than 07bar safely
Type: MK5
Postby flouwford » Fri Mar 25, 2016 4:32 am
No you cant
Model: Ranger
Type: WildTrak
Postby Danger Boy » Sat Mar 26, 2016 7:42 am
Nope 3mm is too much
Model: Ranger
Type: T6 2.2 4x4 D/Cab
Postby StefanRST » Thu Mar 31, 2016 11:15 am
There was at a time 2 Rocam RSi Fiestas that was turboed in Rustenburg,
I know the one guy and he said he was running mercedes pistons on his, not sure which one though,
Must I find out for you or did you come right?
Owner of RST Developments
Ex: Focus ST225 2006
Ex: Syline GTs with RB25
Ex: Fiesta RSi
Ex: Fiat Uno 1.1
Ex: A Crap load of bakkies
Type: 1.6L
Postby Destro » Sat Apr 09, 2016 3:06 am
That would be great help ! Im still eager to turbo my bantum
Type: 1.6L
Postby Destro » Fri Apr 15, 2016 9:04 pm
Maby i can get a copper head gasket made up thats a bit thiker to drop compression ? What do you guys think?
Postby Bloubul7 » Sat Apr 16, 2016 12:41 pm
Destro wrote:Maby i can get a copper head gasket made up thats a bit thiker to drop compression ? What do you guys think?
Speak to Riaan Mk5 on the forum. He dropped my compression by removing some meat in the head. currently running 0.7 bar on stock pistons. Guessing it should be around 130wkw. Compression sitting around 820:1
Postby Kay150 » Sat Apr 16, 2016 1:46 pm
I dont know Bloubul personally but I remember I followed his ST thread as well as the charged bantam thread. This is a man who knows what he's doing.... Take his advice.
Dont judge the man on his avatar lol :lol:
I live my life a 1/4 mile at a time
