Exhaust Design - Backpressure question
Postby Eon » Wed Feb 24, 2016 4:49 pm
I've come to notice that the exhaust shop that originally installed my exhaust had no clue about how backpressure (or the lack thereof) influences power delivery on an NA engine.
I have a 50mm 2-box free flow Cowley stainless steel system with a Steve Wyndham Racing 4-2-1 branch and no cat.
Now while the system sounds great, I'm suspecting that it might be a bit too large for my 1300cc engine. I have also found out that the branch was designed to go with the standard 43mm exhaust, and that I am actually sacrificing precious torque by going thicker. After doing some research it appeared that a 50mm diameter exhaust is better suited to engines with a capacity from 1600cc.
Now I'm contemplating to replace only the section between the branch and the first box with 45mm tubing.
Would this be an improvement, or should I replace all of it? Opinion on the effect of a 'step-up' at or just before the first silencer box would be appreciated!
Type: ST210+
Re: Exhaust Design - Backpressure question
Postby moe676 » Wed Feb 24, 2016 9:16 pm
My personal opinion I think 50mm is fine considering what mods you have and you being at the coast
Current : 05 FIESTA ST 210+
FR&R Dyno 21/03/14 : 145whp 171nm
K.A.R Dyno 07/06/14 : 107.4wkw 175 nm
FR&R Dyno 18/06/15 : 160whp 161nm
